How to modify VE tables
Normally I'm pretty good with technology and can figure things out, but I'm stumped on this one. I have MSDroid on my HTC One and can connect to my MS2Extra setup just fine, but I can't figure out for the life of me how to modify fuel/AFR/ignition tables. I can open the tuning page and see the 3D view of my fuel map, but I can't see to do anything with it aside from rotating it and zooming in and out. I can't see/find any sort of menu button to change to a table view or anything like that. Is there something I'm missing or is the tuning capability just limited?
1967 Dart 5.7 Hemi swap running MS2/Extra
Re: How to modify VE tables
Which firmware are you running? You might need the nodded INI for it to work correctly.
Is that car computer firmware or MSDroid? When MSDroid boots and finds my car it's loading MS2Extra310.ini. The MSDroid version is 1.1r.
Your ECU firmware. MSDroid won't change like your ECU can.
Upgrade to 3.3.2 and then download the modded INI file for 3.3.2 and place it in your msdroid ini folder.
