can you load firmware over bluetooth?
Trying to figure out how to update firmware over bluetooth. I'm using a kindle fire to tune and can't seem to figure out how to accomplish this without a laptop.
Re: can you load firmware over bluetooth?
There is currently no Android version of a downloader. So you need to use a PC.
If your into writing mobile apps this would be a fun challenge. I asked the same question a few months back. The current loader has to send each line of the s.19 file along with receiving a reply from the s12 to check the check sum. This process happens for every line. I believe you can also check entire tables to make sure they were written with the correct data.
http://www.msextra.com/forums/viewtopic ... 36&t=51289
Give this thread a read.
