Blue tooth works great.
Just want to say that MS droid worked for me first time and everytime. I have no issues with it.
BEST thing ever for Megasquirt.
Here is the Blue tooth I installed in the board.
https://www.youtube.com/watch?v=aOEGvK68vos
Ignore what I was saying....was on heavy pain meds at the tie of filming. Crushed disk. LOL
Re: Blue tooth works great.
Same here, happy msdroid user
97 1.8T DIYPNP Seq Inj
http://megamiata.blogspot.co.il/
did you have a link to the bluetooth module you used.looks like it fits nicely.also like that its internal and not a dongle.cheers
Today I mounted my new bluetooth HC-06 module inside my MS2 v3.0
At first it didn't work
The problems were:
- I mounted RX and TX wrong way around
- I didn't change the MS-Droid app setting from EFI-Analystics to my new bluetooth device
After changing these mistakes, it works perfect
I'm so happy with this app and all the possibilities
Thank you again
The problems were:
Thank you again
Opel Corsa A1 C20NE 320 pk 480 Nm 700 kg.
Turbo Garrett T04E35 @ 1,4 bar
Injectors 470cc/min (Opel Z20LEH) Fuel: Octane 102
MegaSquirt 2 V3.0 PWM CL Idle, PWM CL Boostcontroller, 4-Coil near plug, Launch/Flatshift, internal Bluetooth
60ft 1.77 sec. 1/4m 11.8 sec. @ 190 km/h
Awesome feedback!
Are you using 1.1r or the new 2.1 beta build? Either way, the new 2.1 is going to become the current release very shortly. Just doing more testing.
I'm using Version 2.1b1
I hope google will update soon, because my friends would like to use this app also
Same here! bluetooth worked first time and negotiated a link faster than the other android app. I am using a retired sparkfun board with an external antenna:
https://www.sparkfun.com/products/retired/158
I get signal in my house when the car is running on the street! about 30+ feet. This one was $65 at the time. I've run it with MegaTune and TunerStudio as well. Looks like a similar one with a PCB antenna can be had for $25, currently. I didn't want to have the PCB antenna in the case. As it is, I am running a MS3 on a modified MS1-V3 board in the original case (I removed the USB-B connnector) as it fits in the OEM location without issue. How do you guys get the BT signal outside of the case? Do you could run +/- rx/tx outside the case and mount the board to teh outside?
Keith
Keith
I soldered my HC-06 in the proto area
The bluetooth signal goes true the megasquirt box
I have seen people cut a small slot in the case and just leave the pcb part of the board sticking out of the case.
I did this in a bluetooth digital readout for a lathe . It was mounted in a die cast box and it worked fine.
