Hi all,
So it appears the definition INI for MS3 FW v1.3.3 has not been put on the msdroid server (or wherever it checks).
How can the ini be installed manually?
Does it need to be copied into internal-storage/msdroid/ini or somewhere else?
Is the file naming important? If so, what should it be called?
Thanks in advance
No definition file for MS3 V1.3.3 - How to manually install?
Toyota Celica GT4/Alltrac with 5S-GTE stroker (2.2L I4 turbo, high CR) on E85 w/FlexFuel.
MS3 + MS3X + KnockBoard + RTC + BT + DIY CAN-IO-Board + DIY CAN Digital Dash.
Re: No definition file for MS3 V1.3.3 - How to manually inst
Just copy the ini in the ini folder like you said, no special naming required
1993 Chevrolet Cavalier Z24
3400 Turbocharged Inter-cooled
MS3 v3.57+MS3X
MS3 v3.57+MS3X
Too easy, thanks
