Ms2Extra comms333e2 ini file not found
need help with the above please where do i find this
Re: Ms2Extra comms333e2 ini file not found
It is provided in the firmware zip that you used to install firmware to your Megasquirt.
i did try copying ms2extra.ini from that zip file into the ini folder in msdroid but it still comes up saying 'can't find suitable definition file'
i also tried renaming the file to add the 333e2 bit on the end or as ms2extra comms333e2.ini.
Still doesn't recognise it either
Are you running MSDroid 2.1?
I shall ensure I update the server within 24h with the newer ini files including this one. I've got a bit behind with keeping it up to date I think.
hi yeah it's v2.1r1
Thanks much appreciated
Server now updated!
perfect, just tried it and it works now
Much appreciated
Much appreciated
