MS2 custom inc on AD6/JS5 JS4/AD7
Postby MS2tester » Sun Feb 15, 2015 1:19 pm
if one where to have a custom sensor on JS4 and JS5 on ms2
how would you add it to MSdroid
in tunerstudio this custom ini and custom inc file would be in the project folder
setup of msdroid is different offcourse
would you have to add it in the firmware ini?
MS2tester
Re: MS2 custom inc on AD6/JS5 JS4/AD7
Postby MS2tester » Thu Feb 19, 2015 10:51 am
going old school modifying the project ini worked for the standard calculation ( oilpressure )
the custom temp INC is not recognized
i had a copy in the INC folder
and in the project folder
MS2tester
Postby Trev16v » Mon Feb 23, 2015 4:53 pm
Sorry I didn't reply to this sooner. What you eventually did is what I was going to suggest. Is this working okay for you now?
Golf MK2 G60 Syncro with 16VG60 on MSNS-E
MSDroid :: MegaSquirt tuning on Android
Trev16v
Postby MS2tester » Mon Feb 23, 2015 11:38 pm
the custom temp is not working
if you check out the firm ini
you will see that the calculation is there but it will not pick up the temp INC
MS2tester
Return to MSDroid
