if one where to have a custom sensor on JS4 and JS5 on ms2
how would you add it to MSdroid
in tunerstudio this custom ini and custom inc file would be in the project folder
setup of msdroid is different offcourse
would you have to add it in the firmware ini?
MS2 custom inc on AD6/JS5 JS4/AD7
Re: MS2 custom inc on AD6/JS5 JS4/AD7
going old school modifying the project ini worked for the standard calculation ( oilpressure )
the custom temp INC is not recognized
i had a copy in the INC folder
and in the project folder
Sorry I didn't reply to this sooner. What you eventually did is what I was going to suggest. Is this working okay for you now?
the custom temp is not working
if you check out the firm ini
you will see that the calculation is there but it will not pick up the temp INC
