Hi
I have an issue with a Microsquirt Module running MS Extra 3.3.3 firmware
I have MSdroid v 2.4r1 upgraded to PRO and I'm also a ClubGTI member.....
MSdroid 1 was working previously, after manually adding the MSextra 332 ini.
hardware is Google Nexus 7 LTE/4g version running lollipop 5.0.2
connection is though an RS232 to USB adaptor and an OTG
the software recognises the ecu, and fetches an INI, then gets stuck in "synchronising tuning data, Verify tune with main controller" at 0%, now that I manually inserted an msq into MSDroid. Before inserting the msq, the error was "Syncronising tuning data, load tune from controller" and was also stuck at 0%.
I have tried copying the ini files from the ms3extra release333 zip file to MSDroid/ini/ but still no joy
I tried plugging into msdroid 2.4r1 non pro on an google nexus 5 and get the same error.
so it can see the ECU, but wont chat with it. is that right?
I haven't figured out how to get an error log to email you guys....
the status page says:
Currentproject Bananausmodule too many vws. this one is banana yellow.....
Connection Status Reading Version
ECU Signature MS3Extra comms 333eM
ECU Version MS2/Extra Release 3.3.3 20141112 12:53GMT(c)KC/JSM/JB uSM
Configuration file None Yet
INI file Errors 1
Average Poll Rate -
USB Status apparently supported but no adapter connected
Reconnections 0
INI FIle Errors
Line 1003 :testinjcnt : Got too many parameters for scalar contant "testinjcnt", going to ignore some.
HELP PLEASE!
v2.4r1 stuck downloading tune from uS Module 3.3.3
1987 Golf 2 GTI. 2 litre 16v with ITB and MS2 V3.57- has a "Polo" crank sensor. Has extra added quaifeiness. Former BRC group N car, been to Canada and back.
1990 Canadian spec Golf 1 Cabriolet. 2litre tall block 8v running on a Microsquirt V3, hidden in the old Digifant2 case.
Re: v2.4r1 stuck downloading tune from uS Module 3.3.3
The above issue was discussed via emails and turned out to be a USB issue, which was fixed in release 2.4r2.
Oooops!
Indeed the issue was fixed #cough# a little while ago.
I forgot that I had posted here, so forgot to post an update!
