ms2 extra fuel and oil pressure gauge
Use and development of MSDroid tuning software on Android
Postby chango de naranjito » Sat Mar 28, 2015 8:19 pm
Hi, Im using the new msdroid and ms2 333 firmware,how I can add fuel pressure and oil pressure in msdroid with that? it is possible?
thanks, Frank
Frank Racing,Naranjito Puerto Rico,installations and tuning solutions
FrankRacing.Naranjito@gmail.com
chango de naranjito
Re: ms2 extra fuel and oil pressure gauge
Postby econ » Wed Jan 13, 2016 3:45 pm
Hi, I got fuel pressure sensor and EGT working on ADC 6 and 7. I had to configure the channels to the firmware.ini which is in the project folder. You can also add additional channels to logging too in firmware.ini.
Econ
- Ford Taunus Duratec 2.5 Turbo MS2Extra
- Suzuki GSX 750 ER Turbo Microsquirt Module based Sequential
- Suzuki GSX R750W 1993 Microsquirt 3
- MB W124 200E MS1Extra
econ
Postby hybrid » Wed Jun 21, 2017 3:24 pm
Sorry to dig up this old thread, but does anyone have any info on how to add these channels for display and logging in firmware.ini?
Do not load someone elses tune and expect it to work for you!
hybrid
Postby racingmini_mtl » Wed Jun 21, 2017 4:02 pm
hybrid wrote:Sorry to dig up this old thread, but does anyone have any info on how to add these channels for display and logging in firmware.ini?
It's in the manual (at least in part): http://www.msextra.com/doc/pdf/html/Meg ... .4-82.html
racingmini_mtl
Postby hybrid » Wed Jun 21, 2017 4:06 pm
Thanks Jean, I did put my custom ini from TunerStudio into the msdroid project folder but that didn't seem to work. Will have a bit more of a play later.
Sent from my A0001 using Tapatalk
hybrid
Postby racingmini_mtl » Wed Jun 21, 2017 4:12 pm
I'm not sure that MSDroid uses the custom.ini. You will likely have to create a new version of the firmware ini file where you add the equations and definitions from the custom.ini file. Simply add the lines from the custom.ini file at the end of the corresponding sections in the original firmware ini file.
You would need to confirm with the MSDroid people but unfortunately they are not very diligent with support and maintenance.
racingmini_mtl
Postby hybrid » Thu Jun 22, 2017 1:30 am
I'm not stuck on MSDroid.. I've got ShadowDash as well, but it wasn't obvious whether it could do it either.
It will be very rare that I will use the notebook for logging, so really need to have this logging at the very least so I can check it later.
A gauge I can display on my phone is even better, but not absolutely necessary like the logging is.
hybrid
Postby hybrid » Thu Jun 22, 2017 6:00 am
Spot on Jean.
Got it working by copying the sections from custom.ini in TS to the relevant sections in the firmware.ini file in my MSDroid project.
I did notice two entries for the fuel gauge though, so I'm wondering whether it actually is reading custom.ini after all.
hybrid
Return to MSDroid
