How to disable tune difference check?
Is there any way to disable tune difference check upon connection? I'm using the MSDroid as dashboard only and all tuning is done with a laptop. Therefore difference check and question if I want to use tune from controller or MSDroid project is a bit annoying and even possibly harmful. So it would be nice to set the MSDroid so it would automatically update tune from the controller. Is this possible somehow?
Arttu
Re: How to disable tune difference check?
Not sure about your Droid, but in TS: Options>Preferences>uncheck - Perform Difference Report On Connect
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
Unfortunately it seems there isn't such setting in the MSDroid. Or at least I wasn't able to find anything like that.
Arttu
Hello,
Thanks for raising this. It hadn't occurred to me that some users might want MSDroid to automatically update its project tune from the controller. I've added it to the issues list to be done.
Trev
Trev
