Hey all,
I've used MSdroid on my Nexus 5 to connect to my Microsquirt over a RovingNetworks Bluetooth serial adapter and it connects fine. (I can also connect to it with TunerStudio from the laptop fine.) However, when I try to use my old Nexus One, I can pair with the BT adapter and select it in the MSdroid, but when I try to connect it just says "connecting" forever.
Is anyone aware of any hitches when using MSdroid over Bluetooth on earlier Android versions or something? (It runs Android 2.3.6.)
Android can't connect over Bluetooth
Re: Android can't connect over Bluetooth
On earlier versions of Android (2.2, 2.3.x) there were indeed problems with the Bluetooth stack which meant that a few hacks were required to connect with certain Bluetooth interfaces.
You might have some luck if you try another Bluetooth interface. But having said that, a cheap used Android device running a newer OS version may actually cost less than buying a new Bluetooth interface.
