Users with Prolific USB interfaces - please read
Re: Users with Prolific USB interfaces - please read
Postby benckj » Thu Nov 10, 2016 2:26 pm
Sorry, stupid question time.
I need to swap USB ports on my laptop when using the Prolific convertor as it keeps getting in the way with the passenger seat. I understand that the USB port is configured when first using this interface and TS connects after configuration. Is there an easy to change ports without starting from scratch?
jim
MSPNP v2 with 3.57 firmware
Toyota MR2 98 3sgte
TD05sl2-18g (billet wheel & high flow turbine)
A2W IC
WI with 50/50 meth/water
benckj
Postby pinzgauer » Sat Nov 12, 2016 7:07 am
Hmm, is your laptop android? This is the MSDroid forum.
If it's tuner studio from memory it searches for the different ports, and it's also easy to change manually after the fact.
MS Droid and android appears to use the same device, though unless you have a hub it's unlikely you'd have more than one serial device plugged in. And thus no different devices to select from.
pinzgauer
Postby benckj » Sat Nov 12, 2016 11:03 am
Thank you god the reply. I'm working off a PC running Windows and didn't realise this thread was in the Droid arena. Rather than start a new thread figured post was relevant to USB devices.
I will try your suggestion today with port swap but doubt if it will work. I seem to recall using wrong port before and having Comms issue connecting with TS.
Jim
Toyota MR2 98 3sgte
A2W IC
benckj
Postby pinzgauer » Mon Nov 14, 2016 6:19 am
Use device manager to determine which port the serial interface was assigned. Set that in tuner studio, then use the test Comms option.
Sent from my PRC-104 using phonetics
pinzgauer
Previous
Return to MSDroid
