currently testing the can egt in standalone setup
looks great
people with classic cars will be very happy with this
couple of issues however
msdroid will not display the .MDL log shows no data present in the graph
the .MSL log does but there is something off with the AFR reading
it shows 22.00 in the log
while it should read 22.39
BTW this is on a samsung S4
and you have to use serial .ini from jean belanger
the can egt ini from diyautune did not work at-least not with me
msdroid can egt standalone
Re: msdroid can egt standalone
Actually, that's a problem with the ini file I provided to you. After seeing your post I checked it and that ini defines logged AFR only integer value. I have attached a corrected version.
yes that seem to work
could not select the gforces in the log
would that be an ini problem or something with msdroid?
That's an MSDroid parameter so I have no idea if you can or how to have that in a datalog.
