Hello,
MSDroid works great with my MS3 1.4.0, so I wanted to try to connect it to the MSGPIO with Megashift.
I put the right ini file in the ini directory. then I plugged the USB, MSDroid detects MShift 5.101, it finds the right ini,creates the project.
When I then push connect to ECU during the loading firmware process, at 90% it stops, then I have a white screen with "please wait".
And nothing happens anymore.
Is there something else to do I forgot?
Or is there something missing in the ini?
the file used is attached, it was just renamed MShift.ini in Android.
Guillaume
loading firmware blocked at 90%
Re: loading firmware blocked at 90%
Did anyone tried to use MS Droid with Megashift?
