Missing ini on server
Hi!
Can someone help me?
-MS3X, (V3 PCB) 1.2 RC 1 firmware. Controlling a light modified Audi 1.8TQ AEB 20v engine with Holset HE221W turbo, 299.4 HP and 400Nm at the hubs in Dynapack.
Re: Missing ini on server
If I remember right you need to locate the .ini file associated with your MS profile and copy and paste it into the msdroid/ini folder on your phone and it should detect.
Ok! But where can I find my INI file?
In the same zip file where you find the firmware s19 file.eMTea wrote:Ok! But where can I find my INI file?
I tried to copy the ms3.ini file directly to the ini folder on my phone, no success.
Renamed it to MS3_Format_0262.00.ini as the app claims the signature is (and same spelling as an almost similar file; xx.11.ini), no luck.
Any further ideas of how to make it recognize it?
Noone who know how to name the file when added to the ini folder?
Please This is annoying
I'll try again.
I'm running FW 1.2.4 according to tuner studio.
When I view the ms3.ini file, it sais that the signature is 0262.11.
But MSDroid tells med the signature of the ECU is 0262.00.
This ECU has communicated flawless with MSDroid by bluetooth in the past, so I don't understand why it suddenly complains about mismatch.
Open up MiniTerminal from TunerStudio.eMTea wrote:I'll try again.
Type
S
Q
and you'll see the version and internal serial format.
Ok, sorry, my bad, now it tells me that the firmware is 1.2 Rc1, how can I obtain the .ini file for that?
That's an obsolete firmware. Look on your computer for the zip file or upgrade to a more recent version.
I know, I want to install 1.4, but I'm just a little worried about hiccups, since it's a new day, ice racing tomorrow
The last 1.2.x firmware is still available for download and should be very close to the pre-release you are using.
I finally found the ini on my computer, so I'll just keep my 1.2rc1 until I find the time to update, then I'll put 1.4.0, and also clean up my harness and replace the dumb coils to logic coils, using your board.
Thank for your help James!
