Hi, I have a Nexus 7 which works fine with bluetooth connection to Megasquirt PNP Pro 3 ECU. The issue I'm having is direct connecting the ECU with the Nexus 7 directly with a OTG cable from the serial to usb adapter. I know the OTG works with usb sticks but I can't seem to get the MS droid to see it. I've tried the usually stuff, booting with everything running even the car with no luck, unplugging and re plugging etc. Turned on USB debugging, Turned on developer. Other have got it to work with 4.4 firmware but I'm at 6.1 I believe. Any one have any clue?
Also is Trevor is a part of this or is it dead in the water?? Is it over???
Nexus 7 with OTG cable
Re: Nexus 7 with OTG cable
I have the same setup working OK [but with Lollipop].
What USB-->serial adapter are you using [Prolific??] ?
Hello,
No it's not dead and lots of work is happening in the background, but January has been a tough month so far so I may be a little while responding.
Regarding the USB interface you're using, what chip does it use? Prolific or FTDI? MSDroid only ships with drivers for those two manufacturers' ICs.
The first step is to confirm that. If it turns out it isn't FTDI or Prolific, then the next step would be to obtain one that is either of those.
Regards,
Trev
Regards,
Trev
