Hi!
If the BT device is already paired, it will crash the app when I try to select the BT device.
If it's not paired, it will open, and I can go through that menu (but it will not show the device).
Anything I can do, log, etc?
Thanks!
MSDroid crashes when using BT device.
Re: MSDroid crashes when pairing BT device.
Also, is it easy to connect with the RS232 to USB cable? I got an adapter for USB to Micro USB, but I don't know how to set it up, if at all possible.
