msdroid cant find the ini on the database
Postby nismoautoxr » Tue May 10, 2016 2:57 pm
I thought it was giving me this error because I had the development firmware but now its on the release firmware and it still cant find the ini. Does it automatically fetch the ini or do I have to drop it in manually?
Ricky-
MS3&MS3X v.3.0 PCB
LS3/LSA card MAF sensor
97 Mazda MX5
MS3 2002 vvt motor
.60 trim T4 Turbo at 15 PSI
nismoautoxr
Re: msdroid cant find the ini on the database
Postby Kmsgli » Sat May 14, 2016 10:19 am
Drop it in manually from the msextra website firmware that matches your ECU. Just dealt with this issue.
Sent from my Nexus 5X using Tapatalk
Kmsgli
Postby nismoautoxr » Sat May 14, 2016 6:21 pm
I guess I got spoiled by the shadowdash and tu er studio automatically fetching the ini files . I already dropped the ini in manually and it works fine. Thanks for the reply.
Ricky-
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
nismoautoxr
Postby Trev16v » Tue Jun 07, 2016 1:29 pm
Which firmware do you require the definition (.ini) file for? I am behind with updating the server with the newer .ini files, so I am just doing this tonight.
Usually MSDroid fetches the definition files automatically from the MSDroid backend but I'm just in the process of putting the latest definitions on.
Cheers,
Trev
Trev16v
Postby nismoautoxr » Tue Jun 07, 2016 6:42 pm
Trev16v wrote:Hi,
Cheers,
Trev
Trev it is the release fw for ms3 standard ...not pro. I was able to drop it in and get going . I love your app man. It's been awesome. Only a couple small hiccups. Keep up the good work.
Ricky-
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
nismoautoxr
Postby chips60bug » Sat Dec 24, 2016 5:54 pm
Running into this with the latest MS3-Pro Alpha firmware. Tried dropping it in under the project menu on my device and it didn't do the job. Still saying I have a mismatch.
chips60bug
Postby Trev16v » Thu May 25, 2017 7:09 am
I have now added the definition files for MS3 1.5.0 release. Let me know if there are any development firmwares you also want to see added.
Trev16v
Postby chips60bug » Thu May 25, 2017 8:39 pm
I'm running the beta 1 dev, and it would sure be nice if the b2 was supported as well.
chips60bug
Postby chips60bug » Tue Jun 06, 2017 5:55 am
Did anything happen with this?
chips60bug
Postby Dennis_Zx7r » Sat Nov 25, 2017 8:47 am
1.5.1 official has been out for nearly 2 months and isn't in the database yet. Please update this, as putting in the ini on some of my devices is really difficult.
My build (german, page 5+): Link
Dennis_Zx7r
Postby grom_e30 » Sat Nov 25, 2017 11:50 am
This project is basically dead I wasted the £12 quid buying the pro that still don't work properly
grom_e30
Postby chips60bug » Sun Nov 26, 2017 1:35 pm
Trevor has been doing some work lately. Looks like when the new update releases it will be pretty sweet. But i do agree. I spent a lot of money on that app(compared to others out there) and have gotten very little from it so far. I do look forward to the update though.
chips60bug
Postby Trev16v » Mon Dec 04, 2017 12:13 pm
Server is now updated with definitions for MS3 1.5.1 release as well as the MS3 1.5.1 betas (1-7). Please see http://www.msextra.com/forums/viewtopic.php?f=136&t=67894 and let me know what issues you encounter.
Trev16v
Return to MSDroid
