msdroid cant find the ini on the database
nismoautoxr
Post by nismoautoxr »
I thought it was giving me this error because I had the development firmware but now its on the release firmware and it still cant find the ini. Does it automatically fetch the ini or do I have to drop it in manually?
Ricky-
MS3&MS3X v.3.0 PCB
LS3/LSA card MAF sensor
97 Mazda MX5
MS3 2002 vvt motor
.60 trim T4 Turbo at 15 PSI
Kmsgli
Re: msdroid cant find the ini on the database
Post by Kmsgli »
Drop it in manually from the msextra website firmware that matches your ECU. Just dealt with this issue.
Sent from my Nexus 5X using Tapatalk
nismoautoxr
I guess I got spoiled by the shadowdash and tu er studio automatically fetching the ini files . I already dropped the ini in manually and it works fine. Thanks for the reply.
Ricky-
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
Trev16v
Post by Trev16v »
Which firmware do you require the definition (.ini) file for? I am behind with updating the server with the newer .ini files, so I am just doing this tonight.
Usually MSDroid fetches the definition files automatically from the MSDroid backend but I'm just in the process of putting the latest definitions on.
Cheers,
Trev
Golf MK2 G60 Syncro with 16VG60 on MSNS-E
MSDroid :: MegaSquirt tuning on Android
nismoautoxr
Trev16v wrote:Hi,
Cheers,
Trev
Trev it is the release fw for ms3 standard ...not pro. I was able to drop it in and get going . I love your app man. It's been awesome. Only a couple small hiccups. Keep up the good work.
Ricky-
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
chips60bug
Post by chips60bug »
Running into this with the latest MS3-Pro Alpha firmware. Tried dropping it in under the project menu on my device and it didn't do the job. Still saying I have a mismatch.
Trev16v
Post by Trev16v »
I have now added the definition files for MS3 1.5.0 release. Let me know if there are any development firmwares you also want to see added.
chips60bug
I'm running the beta 1 dev, and it would sure be nice if the b2 was supported as well.
chips60bug
Did anything happen with this?
Dennis_Zx7r
Post by Dennis_Zx7r »
1.5.1 official has been out for nearly 2 months and isn't in the database yet. Please update this, as putting in the ini on some of my devices is really difficult.
My project: Link
grom_e30
Post by grom_e30 »
This project is basically dead I wasted the £12 quid buying the pro that still don't work properly
chips60bug
Trevor has been doing some work lately. Looks like when the new update releases it will be pretty sweet. But i do agree. I spent a lot of money on that app(compared to others out there) and have gotten very little from it so far. I do look forward to the update though.
Trev16v
Post by Trev16v »
Server is now updated with definitions for MS3 1.5.1 release as well as the MS3 1.5.1 betas (1-7). Please see http://www.msextra.com/forums/viewtopic ... 36&t=67894 and let me know what issues you encounter.
