I saw this other places but did not see exactly how to fix it. I have ms3x connecting via Bluetooth. Just upgraded my firmware to the newest ms3 firmware and when I try to connect I get this
Also I was able to connect properly with my MS2 setup
Sent from my Nexus 5X using Tapatalk
Ecu definition file
Re: Ecu definition file
Solved it doing a bit more reading. For others looking at this. Download the firmware from your ECU to your phone and copy the .ini file from there into msdroid ini folder and problem solved.
This definition file is now available on the server, so manual .ini copying is no longer necessary. Sorry - I was quite slow in updating the server for MS3 1.4.1 release and the pre-1.4.1 betas that preceded it.
Please let me know that MSDroid can now automatically fetch this file and create a project for you.
