On OTG it´s working ok , but when I try to connect over bluetooth the software stucks on "reading signature".
MEgasquirt MS3
Motorola Droid Turbo
Ideas?
Reading signature
Re: Reading signature
I was having that issue make sure you go into the app settings and choose the Bluetooth device also make sure the device is paired with your phone. I was stuck on that reading signature business for a while too.
Sent from my Nexus 5X using Tapatalk
Has this Bluetooth device ever been used to successfully communicate with your MS before? Is it configured for the correct baud rate? Bluetooth devices need to have the baud rate set on them as appropriate for the MS you're using (9600 for MS1, 115200 for MS2 and MS3). This cannot be done from the app or Android device.
How can you set / check the baud rate?Trev16v wrote:Has this Bluetooth device ever been used to successfully communicate with your MS before? Is it configured for the correct baud rate? Bluetooth devices need to have the baud rate set on them as appropriate for the MS you're using (9600 for MS1, 115200 for MS2 and MS3). This cannot be done from the app or Android device.
Sent from my Nexus 7 using Tapatalk
TVR 390. MS1 Extra, V3 board, EDIS 8 and coil packs
There will be documentation for your Bluetooth interface regarding this. What manufacturer / model is your Bluetooth interface?
