reregistering MSDroid Pro on a replacement device
I just got a new phone and I need to move MSDroid over and I already had Pro upgrade. How do I register it on the new phone without having to pay 18 bux again?
Ricky-
MS3&MS3X v.3.0 PCB
LS3/LSA card MAF sensor
97 Mazda MX5
MS3 2002 vvt motor
.60 trim T4 Turbo at 15 PSI
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
Re: reregistering MSDroid Pro on a replacement device
Hi Ricky,
This should be as straightforward as simply ensuring the active Google account associated with the new phone is the one you previous used to purchase MSDroid.
It's worth mentioning that a new build I just pushed to Play, 2.5r3, has a hotfix to hopefully address a Pro purchase check issue, which is an issue I'm currently investigating. Please try that if you have problems with this.
Regards
Trev
Regards
Trev
