i can,t seem to get any data over the can bus in msdroid
is this a settings issue or is the CAN protocol not supported in msdroid?
MS2 333 release CAN EGT no data
Re: MS2 333 release CAN EGT no data
You should likely update to the current firmware in any case.
I'm not familiar with the current MSDroid release but early versions did not support CAN devices at the same time as the ECU. You had to have a stand-alone setup to view data on the CAN-EGT.
Maybe the latest version does support multi-device projects but I can't say. One thing is certain, the zip file you included does not contain the CAN-EGT ini file but only the link to it on the DIYAutotune web site.
new try with ms2_343B1
but still no luck
but still no luck
