VE table bubble in wrong spot
Using 2.60b and notices that the bubble seems to be inverted on the y axis. In the picture with engine off its sitting at 150%. With the engine running I rides in the 90 to 100kpa area instead of 40 to 50 like normal. When I stab the throttle the bubble falls then raises like the y axis is backwards.
Sent from my SM-G920V using Tapatalk306 SBFord, Torquer II EFI intake, 60 lbs injectors, 8 LS2 coils, VS Racing 7668 turbo, 4R70W, MS3x fw1.4 w/built in trans controller.
Re: VE table bubble in wrong spot
Any help on this? Am I the only one seeing this?
same here
Thanks for reporting this.
