Peak hold for guages
Eddyg
Post by Eddyg »
Hi Trev,
Looked through threads and couldn't find anything so was just wondering if anyone had ever asked or you had looked into a peak hold value for gauges?
When I was running an Apexi power FC the hand commander used to just keep track of the max values which could be quite useful if you were not looking at the gauges all the time.
Don't know how much of a pain this would be but just an idea!
Cheers
Ed
Spiffy
Re: Peak hold for guages
Post by Spiffy »
Bumping this as this is something I would like also, as an option maybe? Also the ability to flip and rotate gauges?
And a follow option for editing ve maps?
Sent fra min HUAWEI VNS-L31 via Tapatalk
benckj
Post by benckj »
Can always use the datalog feature to display all the info and it also lists max/min values for everything recorded.
For real time monitoring I like the idea of the digital value flashing 3 times before it resets. This allows you to note the max value recorded while driving (ie boost, RPM).
jim
Toyota MR2 98 3sgte
MSPNP2 with 3.57 mainboard
TD05SL2-18g with external WG
HKS EBC running 17psi boost.
Spiffy
Post by Spiffy »
Of course but I'm thinking for real time monitoring, like you see in tunerstudio or realdash where an outline of the needle will stay at the max recorded value for some time.
The blinking numerical value isn't a bad idea either, my greddy profec boost controller has that feature
