TinyIOx + MSDroid + generic ADC
Postby turbogrill » Sun Mar 12, 2017 11:55 am
I want to add oil pressure, oil temp, fuel level to MsDroid. Can I add all these sensors as ADC into TinyioX and display those gauges in MSDroid?
So I want MSDroid to show fuel pressure, oil temp, oil pressure and fuel level using TinyIOX.
Something like this, http://i.imgur.com/yUjCfSz.png
turbogrill
Re: TinyIOx + MSDroid + generic ADC
Postby racingmini_mtl » Sun Mar 12, 2017 12:42 pm
Which MS are you using? And are you currently reading the TinyIOx analog channels from your MS?
racingmini_mtl
Postby turbogrill » Sun Mar 12, 2017 2:19 pm
I am using Microsquirt, it only has 2 spare ADC.
I am don't own a TinyIOx. I will only buy one if it's possible to show custom ADC channels in MSDriod, otherwise I will make my own solution using Arduino.
Seems like it should be possible from Tunerstudio, at least what I have seen from screen shots.
Thanls
turbogrill
Postby racingmini_mtl » Sun Mar 12, 2017 2:47 pm
You can easily do that with TunerStudio but I don't know if MSDroid has the same possibilities. At the very least you should be able to get up to 8 custom ADC channels using CAN polling on the Microsquirt but that may require updating the ini file to do so.
Someone with better knowledge of the latest MSDroid version would need to answer this.
racingmini_mtl
Postby turbogrill » Sun Mar 12, 2017 2:58 pm
Maybe shadow dash can, will ask in that forum.
turbogrill
Return to MSDroid
