Bluetooth adapter for microsquirt and msdroid
Postby gui67 » Mon Dec 25, 2017 4:01 am
Hello,
Is there a possibility to use a Bluetooth adapter on microsquirt?
Maybe a version with 5v, in order to be able to use the Vref to power supply it.
Has someone already done that?
Msdroid is currently working with USB otg, but as soon as the engine starts it gets disconnecred, maybe due to interference...
Guillaume
gui67
Re: Bluetooth adapter for microsquirt and msdroid
Postby racingmini_mtl » Mon Dec 25, 2017 10:30 am
Vref from the Microsquirt cannot supply enough current for a Bluetooth adapter. You need one that connects to the car 12V.
racingmini_mtl
Postby gui67 » Mon Dec 25, 2017 3:11 pm
Thanks Jean,
Are there some reliable boards for 12V-->5V power supply?
How powerfull is the microsquirt power supply, compared to the other Megasquirt? MS3 on V3.57 and MS3pro?
I was using a Nextion HMI powered by the µsquirt Vref on a friends car, maybe it is not so good an dI should build a separate power supply too. this models takes up to 85mA
The 7" I am buiding for a MS3pro takes 510mA... I will certainly need an other power supply too.
For the bluetooth adapter, if I understood correctly:
this model:
https://www.ebay.com/itm/1pcs-HC-05-Wireless-Bluetooth-RF-Transceiver-Module-serial-RS232-TTL-for-arduino/251886755046?epid=676005030&hash=item3aa59edce6:g:6OUAAOSwrklVDCUp
for inside casing, connected to the CPU pins, directly in TTL, power supply 5V: internnaly for Megasquirt or external for Microsquirt.
This model:
https://www.ebay.com/itm/DB9-RS232-RF-Wireless-Bluetooth-Module-HC-06-Slave-Serial-Port-For-arduino/141875967366?hash=item2108777586:g:EIcAAOxy3yNTfvzj
or https://www.ebay.com/itm/RS232-Bluetooth-Serial-Adapter-Communication-Module-MINI-USB-5V-Interface-TE607/232278042750?hash=item3614d9a87e:g:TTkAAOSw3gJZEMzn
for outside DB9, integrate the MAX 232 to switch again the signal in TTL. also requires 5V external power supply for the microsquirt.
Am I correct?
Tanks
Guillaume
gui67
Postby Suprazz » Mon Dec 25, 2017 6:30 pm
My bluetooth adapters work well on the microsquirt.
But I also made recently a plug and play version with the 2.5mm stereo plug and 12v supply.
If you're interested, just let me now!
Sam
Suprazz
Postby gui67 » Tue Dec 26, 2017 12:53 am
Thanks Sam,
What is the cost of the 12V version?
I also have found a module with a 12V input:
https://m.ebay.com/itm/Bluetooth-Module-RS232-TTL-4-pin-7-25V-TTL-5V-Buffer-EQ-MOD-12V/172876717332?_mwBanner=1
Would this one work with Ms and microsquirt?
Other question, what could I use as 5V powersupply for a Nextion screen in order not to overload the MS Vref?
Guillaume
gui67
Postby gui67 » Tue Dec 26, 2017 1:41 pm
Is this component OK for powering a HC05 and Nextion screen from the 12V?
https://www.digikey.com/product-detail/en/OKI-78SR-5/1.5-W36-C/811-2196-5-ND/2259781
Guillaume
gui67
Return to MSDroid
