Remote Tuner Available
Re: Remote Tuner Available
Send me a PM or email dac@wctel.net with pricing.
66 Mustang Turbo 6.0 LS on MS3X 80lb Deka injectors Tunerstudio Ultra and MS3 1.5.1
I could probably use some help getting this dialed in. Email is dragbug@gmail.com.
1966 Mustang Fastback
302 HO,Trick Flow TW 170 heads, Headers/dumps, MS3
PM's and emails sent.
Graduate of EFI University.
Hello - Can you give me an idea what your costs are. Trying to tune a 2 L 16v VW with ITB, 12.5 compression and big cams. Currently working on Alpha-N but probably should be ITB.
Gary
Gary
Interested in a little setup help- I'm almost there but need the finishing touches to the base settings and a little timing/ data logging. Can use remote tunning if best.
635csi with gt35r turbo
Ms2 with boost control
All the normal stuff
Phil400@att.net - pricing info please!
Email sent.
Im looking for some tune help as well. I sent a PM to your user. Thanks
PM sent.
I need help tuning my ms1 16v turbo setup. Can you give pricing info please.
he is helping me with my tune right now, ill post back with final results
I have a dyipnp d56 89 5.7 TBI K1500 GMC I have built. The base maps are in an older revisions and do not load properly. Do you have a base load I could use to get started. I am using turner studio. I can also allow you remote access to the PC I am tuning with. Would you be interested in assisting.
Sandy
Sandy
94_cobra wrote:he is helping me with my tune right now, ill post back with final results
Although he was patient and had a fairly quick email response, I felt that I should have got a more refined tune. Maybe i was spoiled by the quality of previous help. The car started and idled and that was his base tune. Maybe if I paid for the next step it would have been better, but all in all I was happy with the car starting and idling. If you dont have a local megasquirt tuner im sure he can definitely help you out.
Austin
I certainly apologize Austin if there was a misunderstanding, from the options I offered I understood that you wanted me to prepare your base file for tuning. Tuning is a process that optimizes the performance and driveability, the base file is a solid foundation on which to begin tuning. Without the solid foundation you can certainly never get the car working the way you'd like and it is important to note that you are different and your motor is different than any other out there, even two motors with exactly the same components will ultimately arrive at different timing and fueling requirements for optimum performance. That is why the better term for the process is calibration, you essentially calibrate the motor for the given fuel quality and the idosyncrasies of the operator.
But I do applaud your desire to learn the process yourself and I see you're getting quality help with your latest challenge. http://www.msextra.com/forums/viewtopic ... 01&t=57405
1990 5.0 302 turbo with MS2 V3.57 PNP. Please PM or Email htgomez09@gmail.com. I'll need some help.
1990 Mustang: MS3Pro Gen 1, 306ci, 72mm turbo, 80lb inj, 36-1 + Cam Sync + D585 coils, World heads, TFS1 cam, GT40 intake, auto, Speed Density
1987 Mustang: MS2v3.57, direct coil control, MSD VR Dizzy, SBE, Weiand 174,190cc heads, F303 cam, TBI w/ (4) 160lb inj, GT500 MAF
Mk1 golf 1.8 20vt. Looking for a base tune to get it running properly. My email is joralexander1@gmail.com If you could send me an email that would be great.
Thanks in advance,
Jordan
Thanks in advance,
Jordan
Emails sent.
Hello elutionsdesign, I posted a while back about some tuning help. Sorry I never got back to you! My miata will be coming out of storage in a few weeks and I was hoping to get some remote tuning done. Would you be able to refine my idle as well as take a look at the current maps? My idle is a sore point for me, I just cant wrap my head around getting a smooth idle. Is that something you can do remotely? Would you do this via a remote desktop session? Or would I send you previous logs and you would poke around those?
Thanks!
Thanks!
PM sent.
Email sent.
