Remote Tuner Available
Post here if you are seeking local tuner assistance
elutionsdesign
Re: Remote Tuner Available
Post by elutionsdesign »
Contact made.
Graduate of EFI University.
Buckles
Post by Buckles »
I need help with cold start idle on a 1991 Miata with a 2002 engine swap, MS3Basic, and some other tweaks. Can you PM me what you can do and how much? I can give you car details in PM. Thanks!
elior77
Post by elior77 »
Hey, I can help MS users with there tune, PM me.
97 1.8T DIYPNP Seq Inj
http://megamiata.blogspot.co.il/
elutionsdesign
elior77 wrote:Hey, I can help MS users with there tune, PM me.
Start your own post please, don't ride mine.
elior77
Post by elior77 »
Sorry.
585AW11
Post by 585AW11 »
hello would love some help dialing in my tune before the dyno. PM me if your not overwhelmed. thanks.
elutionsdesign
PM sent.
wrap.
Post by wrap. »
I've had my MS3 installed since 2012 and have spent most of that time dealing with all sorts of issues; cold/hot start, idle, drivability, injector setup, etc. In the beginning I was more than happy to attempt sorting things out myself but as time went on it was no longer fun, and just became frustrating. So I came on here recently looking for help and found Scott, a days later my ECU was on it's way to him. After he rectified some issues, made me a VR conditioner, the ECU was back in my hands along with detailed instructions. Once everything was properly installed, I sent him some data logs and it was off to the races. Scott made adjustments to the tune based on my data logs and I had a new car...what a difference. :yeah!: The car is so much better in every aspect, I mean not only does it start, run and drive better but it also feels more powerful, WOW!!!. I actually enjoy driving the car once again, my only issue is not finding Scott sooner. Thank you. :D
Don
Post by Don »
Hello, I am needing help with my old school, previously a turbo basket case,VW sand rail. Ms2extra, 48 lb injectors,turbo, 36-1 VR crank trigger 1915.
1988 RX7 Turbo sand rail. 80mm Billet TB, 4) 48lb Accel disc injectors, Stock coils, MS3x V3.57, MS2/Extra w/ knock module. 10 PSI boost w/ T04 Turbo, LC-2 O2 controller, Home built Intake Manifold, fan cooled oil & intercooler, Bus 5-rib 002 Trans w/ close ratio gears, 4.86 final drive.
elutionsdesign
Contact made.
black85ptype
Post by black85ptype »
hi i have an 83 celica supra 2.8l set on 10lbs of boost im using 285cc injectors im currently living in yelm washington i need a base map for my car please contact me asap im running ms2x firmware
Rick8282
Post by Rick8282 »
Wadae11
Post by Wadae11 »
Looking for quote for basic map file possibly remote tuning
wadepersons@yahoo.com
Engine/Transmission/ECU
• 2.0 ABA Full Rebuild (Bored/Decked/Balanced)
• 83mm Forged Pistons
• 2.0 16v Head Port/Polished Rebuilt with 3 angle
• Autotech Cams
• Autotech HD Valve Springs
• Autotech Adj Timing Gear
• Autotech headers/high flow cat
• 1.8T Injectors
• BBM Fuel Rail
• Eurosprt Plug Wires
• BBM Block Off Plate (oil breather)
• Custom Hyabusa ITB Setup/Customer Intake Mani
• Diesel Starter
• 50mm Velocity Stacks
• O20 Aug Trans W Bolt/Peloquin 80% Kit
• Paratron Mega Squirt (fuel/spark) Setup MS2 v3.57
• Innovation LC-2 Wideband
elutionsdesign
Contacts made.
carlmx72
Post by carlmx72 »
I have a (ms2e v3.0 board, latest firmware) 86 Toyota Cressida 5mge with 7mgte turbo and 440cc injectors. I have had the car running and driving (in a parking lot) but after wiring in the factory IAC stepper motor as a 4 wire GM style the factory 24/2 distributor pickups are loosing sync. The engine will start, but rev to 1300rpm then loose sync and drop to 0 then back to 1300. Over and over. I am near Portland Oregon. Thanks.
1986 Toyota Cressida wagon 5m-gte
water to air intercooler
stock turbo parts off 1987 Toyota supra for now
JoelBear
Post by JoelBear »
I know you're busy... I read the posts using ms2extra 90 talon tsi awd. While my car runs and drives fine it's rich on idle idles rough when in boost she pulls like a rocket I have a tuner but he has a full time job and I haven't seen him since april we got no where with the tune. My maps are all over the place and megasquirt is far more advanced than ecm link help
elutionsdesign
PM's sent.
63 Bug
Post by 63 Bug »
I've got a Subaru 2.5 with TD05 turbo, I've got it running and idling (badly) so would like a price for remote tuning please
Its on MS2/Extra
elutionsdesign
PM sent.
Gsyk59
Post by Gsyk59 »
Hello, I'm putting together a 2001 Miata with a Rotrex kit and Megasquirt MS3 (built by Reverent). Looking for help with the tune. Can you let me know remote tuning costs?
