Remote Tuner Available
Post here if you are seeking local tuner assistance
Postby elutionsdesign » Fri Feb 28, 2014 10:43 am
I've been building, installing and tuning Megasquirt systems for five years, located in Bellingham WA USA but I've helped guys tune via email all over the world. I've done sports, 4X4's, DD's, dyno tuning for power, dragstrip tuning and tuning for economy. Happy to help! I also build custom harnesses and work on Halltech, FAST, Electromotive and other equipment including modification and repair.
Graduate of EFI University.
elutionsdesign
Re: Remote Tuner Available
Postby Locost7 » Mon Mar 10, 2014 6:01 pm
2014-03-10_17.50.19.msq
I'm in need of a little help. I have a Toyota 20V Corolla in a Lotus 7 replica running MSII Extra PCB 3. Always been running way rich but now it's over the top. Only have about 375 miles on it. I had made some changes that only made things worse so I loaded a MSQ that it did run ok on. Now it's displaying bad TPS symptoms.
Have a registered version of Tuner Studios but this is all over my head.
Would appreciate your help!
Larry Jackson
Seattle
mbnlwj3@gmail.com
Locost7
Postby elutionsdesign » Sun Mar 16, 2014 10:55 am
Email sent.
elutionsdesign
Postby NWABrewer » Wed Apr 09, 2014 2:10 pm
I have inherited a 280ZX with a MegaSquirt system installed. I am way over my head and could really use some help.
Would you mind sending me your email, and I can get you some specifics about the setup.
I would appreciate it,
Sean
sabanstorm@gmail.com
NWABrewer
Postby Fatvod » Mon Apr 14, 2014 1:43 pm
I would love some help getting my tune perfect! Its a 1992 mazda miata.
Thank you :)
Fatvod
Postby carlanderson93 » Tue Apr 15, 2014 1:38 am
Hi, I've got a modified 74 BMW 3.0 CSI which is now a 3.5 with a hot cam, wasted spark ignition, etc.... I also just installed the MS 2 EMS at my mechanic's endorsement. I really need some help getting things straightened out there. It runs but it is not even close to road ready. There are a couple of issues (poor idle, not starting initially, poor throttle response) but nothing I don't thing someone with your experience couldn't figure out rather quickly.
I know you'll need a copy of my msq file and perhaps a data log. I just need to know what engine specs you need to know to make informed decisions, if you're interested in taking on the project and an estimate of cost to do the work. You can contact me at oilcan93@yahoo.com. Thanks for your time!
carlanderson93
Postby elutionsdesign » Thu Apr 17, 2014 3:49 pm
Emails and/or PM's sent.
elutionsdesign
Postby nathanhardy » Thu May 15, 2014 4:55 pm
What is your cost and have you worked on vr6 vw's?
98 VW golf gti vr6 turbo 8:5:1 cr, ported and polished, race valves, springs, 262 cams, custom short runner intake, water cooled bb t4t3 60 trim turbo, forge wossner pistons, dressed rods, balanced rotating mass, custom oil pan with baffle, limited slip 5 speed trans, ID 1000's Running strong on ms2
nathanhardy
Postby elutionsdesign » Fri May 16, 2014 8:48 am
PM sent.
elutionsdesign
Postby duweeee » Thu Jun 05, 2014 9:13 am
Do you have an email address I can email you at?
duweeee
Postby elutionsdesign » Fri Jun 06, 2014 6:32 pm
PM sent.
elutionsdesign
Postby NordicKitsune » Sun Jun 08, 2014 12:39 am
i need some help, im just south of you in Portland OR
1973 Volvo P1800 with a B20 (volvo not honda) motor, converted from D-jet to MS2extra
starts and idles ok but not great, will not rev past 1700rpm ish, stationary or under load.
attached are the MSQ and a datalog
NordicKitsune
Postby elutionsdesign » Sun Jun 08, 2014 10:14 am
PM sent.
elutionsdesign
Postby maverickh1l » Sun Jun 08, 2014 4:32 pm
I'm in desperate need of some help. I'm running, for all intents and purposes, a GM 3100 V6 with 11.4:1 compression, 1 BAR GM MAP and Ford MAF, DIS, and 22# Corvette fuel injectors (with adjustable fuel pressure) in my 88 Camaro Z28, which is being run by a MS2 v3 with B&G v2.92 code (because I couldn't get MS2Extra to run at all). I have a knock sensor, but I've had false knock readings since I got this thing running. I've had this thing running for about a year now, only doing serious driving tuning over the last 9 months. It idles okay. Acceleration is dirt poor. Fuel consumption is WAAY too high for my tastes. My Innovate LC-2 is indicating running seriously rich from one corner of the VE table to the other. I've tried adjusting pretty much everything to get the AFR in line, but to no avail. It seems like this thing just doesn't want to run properly with an AFR even close to stoich. I've got a serious lag in acceleration, for starters. This car would be my daily if it were running decent, which it's not. I'm hoping the costs won't be too excessive, as I don't currently have much. What I would ideally like is to be able to use the full potential of the engine when necessary and still get about 30 MPG, which is what the base engine got stock.
My email is maverickh1_l@yahoo.com, and I am ready to provide my latest datalog and MSQ package upon request.
maverickh1l
Postby elutionsdesign » Sun Jun 08, 2014 8:02 pm
Email sent.
elutionsdesign
Postby ddoc » Mon Jun 09, 2014 3:51 am
Hi!
I have alfa romeo 164 3.0 ar66303 engenie and try to instal MS2EXTRA v3.0
fore stroke engenie
6 cilindres
ignition trigger 60-2
wastedspark 2+2+2 (connect with external 3 ch driver Bosch 0 227 100 203)
MAP 21psi
IAT +125 C
IDLE valve (3 pin) connect with another driver Bosch 0 227 100 203
Fuel
6 inj 189cc
connect - MS internal driver (2 ch 3+3)
Can You remote help ?
ddocrab@gmail.com
skype dograf_r
ddoc
Postby elutionsdesign » Mon Jun 09, 2014 7:26 am
Email sent.
elutionsdesign
Re: Remote Tuner Available....Thanks!
Postby carlanderson93 » Tue Jul 15, 2014 4:30 pm
So Scott got his hands on tuning my BMW 3.5 CSI with MS-2 after my mechanic left with the car running.....but not well. What a difference! After a few tuning then data log sessions, I can not believe the difference. GREAT throttle response and the torque band is great in every gear under all loads! Thanks, Scott. I'll be back when I finally add that turbo! ;-)
carlanderson93
Postby 12gauge » Sun Jul 20, 2014 5:09 pm
Hello! I have a 1989 Mazda B2200 with a F2T engine swapped in, a Ford EDIS system, and MS2v3.0 but I haven't been able to get even a base tune in the MS or more than a cough out of the engine. I'm down in Seattle and could very much use experienced help getting this project programmed. Please, email me at 12gamakeover@gmail.com and let me know what more info you need. Thank you, in advance.
12gauge
Postby boukman » Thu Jul 24, 2014 10:18 am
How much for remote tune please?
Regards.
boukman
Next
Return to Find a tuner
