Traveling and Remote Tuner available
I'm available primarily in the Nebraska / Iowa area, but I travel frequently to the following cities, check with me if you need help in these places:
Sacramento/Chico, CA
SoCal
Dallas/Fort Worth, TX
Atlanta, GA
Kansas City, MO/KS
-I have experience with everything from basic DIY/junkyard combinations to max-effort competition engines, and a decent success record
-I've tuned a vaiety of engines up to 4000hp, and 10hp per cubic inch.
-I'm fluent in most makes of chassis and engine dynamometers
-I calibrate a variety of different OEM and aftermarket control systems on the following fuels: dry (propane, LNG), gasoline, methanol and ethanol
-I have experience with street-driven, street-strip, drag racing, landspeed racing, and little bit of roadracing applications, both forced induction and naturally aspirated
- references available on request
Contact me with questions at: scottdclark@yahoo.com or 402-680-8853
SoCal
Atlanta, GA
Kansas City, MO/KS
Squirted: it's easier to list the ones I haven't squirted. I need to do more motorcycle engines!
Re: Traveling Tuner available
What part of Nebraska are you in normally ?
mr_minnis wrote:What part of Nebraska are you in normally ?
Omaha area is my home. I live just across the river from Omaha, near Treynor IA.
Re: Traveling and Remote Tuner available
Just sent you an email.
I'll put a plug in for Scott. He's a great guy and he knows what he's doing. He went out of his way to help me out and I have a feeling that is how he operates normally.
when will you be back to the chico area, I live in orland 20 miles west of chico. I am currently working on a hard throttle stab at idle that causes the engine to die. But only a very hard stab at idle... if I bring the engine up to 1700 rpm the vehicle will just launch,,,, no die. only dies from idle.
looking for a quote to tune my 2276 vw it starts but rough need a daily driver email me ruby59vw@gmail.com
Scott,
I need some help to solve the installation & tuning problem. See 2 separate threads posted:
http://www.msextra.com/forums/viewtopic ... 10#p412810
http://www.msextra.com/forums/viewtopic ... 03#p456003
Can you please PM me to discuss about remote help & pricing?
thanks!
thanks!
Hi I'm new to the community and new to mega squirt I'm waiting for my computer genius to finish assembling my board so I can set it up I have a very highly modified 22re. And will need help setting up the tune. I'm in Sacramento California. Do you still come out this way I tried to PM you but I couldn't find the link. Please pm me or something so we can talk about it.
