NEED A TUNER/REPAIR SHOP IN SOUTHERN CALIFORNIA
I own a vintage BMW with a M30B35 with an upgraded cam. Prior to recently moving to Southern California I had the new cam installed and at the same time was converted from Motronic 1.3 (with a Dinan chip) to a Megasquirt PNP2. While the engine performs great I am having a "run on" (dieseling) problem. Ninety five percent of the time I turn off the ignition the engine runs on (often time I use the clutch to stop it). I did not ever have this problem before the Cam/PNP2 install but has been constant since. I no longer have access to the shop that did the conversion, and am looking for a Southern California tuner that also can trouble shoot this problem and do the necessary repairs. Thanks.
Re: NEED A TUNER/REPAIR SHOP IN SOUTHERN CALIFORNIA
You can read here to try to ID the problem. http://en.wikipedia.org/wiki/Dieseling
Kenny Lyon
(310) 631 3460
kenylyon@hotmail.com
http://www.facebook.com/keny.lyon
www.goldwingracingproject.info
http://GoldWingStreamliner.com/
Kenny Lyon
(310) 631 3460
