Looking for Tuner - Essex UK
Hi All
Does anyone know of a tuner in Essex, UK? Unfortunately a lot of the tuning shops around here specifically state they won't tune MS.
Ta
Cam
Ta
Cam
Re: Looking for Tuner - Essex UK
There's a good reason for that. Some DIY MS installations don't just need tuning - they need fixing first. And fixing a one off can be very time consuming so expensive.
Have you got a wideband O2 sensor fitted and working? With that VEAL will get you pretty close. At less cost than a single rolling road session.
Hi, I've got a wideband o2 (and Tuner Studio with VEAL) and will be looking to do as much as I can on the fuel tables. I'd just like a professional to then check it's safe/finish it off and tune the ignition table on a dyno
The snag with pro tuning is it's easy enough to get max power set up. It's all the rest of the curve which takes the time. I'd be inclined to use an MS specialist for the tuning - even if it does involve some travel. It's such an expensive business, you want the best value.
That's fair enough. Do you have any recommendations for who I should use?
Ta
Ta
There is a well recommended chap in the Norwich area, IIRC, so not really that far. Perhaps James will remember? I've never used a tuner, so can't myself.cammmy wrote:That's fair enough. Do you have any recommendations for who I should use?
Ta
Great, thanks.
How do you tune ign tables? Do you have access to a dyno/hire dyno time and do it yourself?
Ta
Ta
Northampton motorsport will map ms.
Brilliant, thanks
I started out with a curve based on the figures given in my factory workshop manual.cammmy wrote:Great, thanks.
Ta
In case anyone else needs a tuner in Essex. Torque Developments International will work with newer models:
Grays, Essex RM20 3XD
Ta
Cam
Ta
Cam
hi all, this is my first ever go at this, so please excuse any lack of protocol. Ihave a home built ms3x and i have many sync errors, im sequencial spark and fuel so so have 36 tooth crank and single tooth cam vr sensors. im 57 years old and live in chelmsford essex, im hoping it find a fellow enthusiast close enough to lend me a hand or bang heads together, the engine a hayabusa turbo, can anyone help thanks in advance nick
