Here's what I got:
MEGASQUIRT III v3.57 with MS3X Expander board
JIMSTIM v1.5 with wheel simulator v1.5
TUNER STUDIO MS v2.6.14
Car is wired and ready to go. I ran Tuner Studio with the JimStim and MegaSquirt and got a "Not synced" when I adjust the RPM. Other pots appear to be working. What do I do next? I am new to EFI, tuning and MegaSquirt and have reached the limit of my ability. Anyone want to help me out, please? I would be interested in hiring a local tuner to help me if there is one? I am in Marin County/San Francisco Bay Area.
1976 280Z - Nissan 28L 6 Cylinder bored and stroked to 3.1 liter. Normally aspirated EFI. 245HP.
INTAKE MANIFOLD – P82
EXHAUST – MSA header
HEAD – N42
CAM - Grind: 17034. Lift (In/Ex): .460/.460. Duration (In/Ex): 270/280. 3000-6500 RPM.
BLOCK – N42
IAT - GM Open element
O2 SENSOR – Wideband
THROTTLE BODY – Nissan 60mm
TPS – Nissan 240SX 3 wire
MAF – Nissan Z32 4 wire 91-96 N62 or 91-94 N60
INJECTORS - 265cc 44 psi 2.3 to 3 ohms/3.3 25w resistor
DISTRIBUTOR – 1983 280ZX Turbo optical dizzy with DIY trigger wheel
SPARK PLUG – NGK BPR6ES
COILS – Coil on plug Ford DG 508
QUAD SPARK – 2 installed.
MegaSquirt, JimStim and Tunner Studio help needed
Re: MegaSquirt, JimStim and Tunner Studio help needed
Can you make a tooth log of an attempted start? This will tell us more about the RPM signal that is getting through to the ECU.
Check that you have set the dil switches on the JimStim to the correct type of rpm output for your MS settings and also that you have the jumper set for the correct pull up. 12v I think.
