Need a tuner in San Antonio/Austin TX area
Post here if you are seeking local tuner assistance
Postby Derek13p » Thu Jul 13, 2017 2:16 pm
Me and my roommate built his Mazdaspeed Miata engine with upgraded rods and pistons and upgraded the entire valve train minus the cams themselves. Custom exhaust manifold with a GTX3076R turbo, MS PNP, stock fuel and ignition system and stock o2 at the moment. Also stock trigger wheel. Wanting to get a base map to get the car running with no MAF sensor if that's possible while I get the engine broken in and get the fuel and ignition system upgraded and but a new damper with trigger wheel and wideband O2. Stock ECU will start the car but don't want to run it on the stock ecu with no fail safes right now. Any info or a point in the right direction would be appreciated!
Derek13p
Re: Need a tuner in San Antonio/Austin TX area
Postby quan3165 » Mon Aug 07, 2017 6:14 pm
I may be able to help, but not until you have installed your wideband and upgraded your fuel system to support your intended hp. I have a WB sensor I can use to tune if you do not want to buy one, but it would be a wise decision to have your own.
I'm in Houston and I am familiar with MSMs, PM me if interested.
quan3165
Return to Find a tuner
