newbie in Adelaide Australia
Post here if you are seeking local tuner assistance
Postby danbeck » Mon Nov 06, 2017 4:19 am
Hi guys
MASSIVE learning curve learning how to tune my MS2 porsche 911 2.7 with ITBs. Ive sent my files to the guy I bought the kit from and hopefully he can modify it as its too rich through the rev range and too lean at idle.
Does anyone know of someone who tunes megasquirt in Australia (ideally Adelaide)? Can I tune it without a dyno if someone can look at my logs and change my tune remotely?
Any advice is appreciated
Cheers
Daniel
danbeck
Re: newbie in Adelaide Australia
Postby benckj » Mon Nov 06, 2017 8:11 pm
Best you install a wideband O2 and get connected to MS using VEAL. Once you get the AFR tables sorted and a little help from this forum the auto tune function will sort out most of the fueling issues. It’s a steep learning curve at the start but will all make sense once you get started. I was much the same a year ago.
Jim
MSPNP v2 with 3.57 firmware
Toyota MR2 98 3sgte
TD05sl2-18g (billet wheel & high flow turbine)
A2W IC
WI with 50/50 meth/water
benckj
Return to Find a tuner
