Looking for a Tuner in Florida
like title says looking for a tuner in the tampa bay area, I have a 1jz with a single 6262 T3 turbo, 800cc injectors, Fuel regulator, Quantum 340lhp fuel pump, R154 Gear box with Spec 3 stage 6 puck clutch, hks boost controller. just installed a MS3X and have it running with a 2jz base tune.
Re: Looking for a Tuner in Florida
You might want to talk to Jordan at Powersquirt Industries. He's got a lot of Toyota experience.
http://www.powersquirt.com/ EDIT: <--- dead link
Hi - that link was to an Adidas website (maybe it's dead?). 1jzTaco - did you end up finding a tuner? I'm also in Tampa, also with a 1JZ and looking for a good local tuner. -Eric
I don't have Jordan's 1JZ/2JZ experience, but I am a full time MS dealer/tuner in Melbourne FL and have access on site to a Mustang Chassis dyno
Support the developers!
Bumping this as I'm also looking for a tuner in the Tampa Bay area.
My setup:
1.5JZ non VVT-I with harness converted to USDM 2JZGTE
Hellcat 525 Pump and PTFE Fuel Lines
MS3 2JZ PnP ECU
1000CC Injectors
Aeromotive Regulator
S360 Turbo
AR5 Transmission
1ZZ Coils
USDM 2JZGTE Cams
Factory FFIM
E85 Sensor and Fuel Pressure Sensor
EBC
I am open to Jordan is south Florida but would obviously like to find something more local first.
Thank you!
Edit: Got here from Google. Did not see the related post at the top of the forum.
My setup:
MS3 2JZ PnP ECU
1000CC Injectors
S360 Turbo
AR5 Transmission
1ZZ Coils
USDM 2JZGTE Cams
Factory FFIM
EBC
Thank you!
