Is it possible to output the same VSS pulse count as the input? For example the 4T40E has a 40 tooth reluctor wheel at wheel position ( effectively ) Can I output that same 40 pulse per wheel revolution signal and if so, how? I have the hardware side of it solved but I'm not sure about the firmware settings. Just trying to cover all bases here in case the people at AIM can't get their software modified for the new VVS location via CAN in a timely manner.
Jeff
VSS output
VSS output
Support the developers!
Re: VSS output
Not possible presently, but it should be do-able.
