To announce the pre-1.0 RC1 version of the Microsquirt trans code.
Customer feedback has been positive and the code appears to be stable, so I have decided to move this towards a "release" name by naming this "Release Candidate 1". So long as no problems are reported, it should be promoted to release fairly shortly.
Changes since the last (0029) release
Bug fixes
New / changed features
MS2 sel D input is PE0/JS7
Make pin names more logical by product.
Minor / internal
ini tweak to allow up to 2047 CAN offset.
Tooltip tweaks.
Tiny defaults tweak.
The zip can be downloaded via:
http://www.msextra.com/downloads/dev/tr ... -1-0-rc1//
The updated manual is included.
Successes, failures, bug reports and suggestions welcome here.
Trans control - pre-1.0 RC1 released
Re: Trans control - pre-1.0 RC1 released
there was 2 things i was going to ask for before the code got this far but im a bit late. ill ask anyway
1. have shift tables on tps and pressure tables on map, this is mandatory on a turbo car for correct shifting AND line pressure
2. a spare output. when i had the gpio in my car i ran a fender mounted trans cooler with a fan set to come on above 150*
Those are reasonable suggestions, but I think they'll have to wait until after 1.0 is release and will be part of a pre-1.1 beta code.
(The code naming isn't a big deal, but I'm keen to reach "1.0" and then continue with dev versions as normal.)
Any feedback on this release yet?
Working spot on with my 4T40E project!
Support the developers!
