a few feature requests
Postby ashford » Sun Jun 11, 2017 8:11 pm
i've been putting off making this post for awhile now. i have a few things i would like to see get added or changed
first the easier things
1. be able to change leaving torque locked during shifts. leaving it locked on shifts on high stall converters is a necessity to avoid rpm flares between 3-4 shifts while converter is unlocked. for example light acceleration running at 1800 rpm in 3rd unlock for 4th rpms jump to stall speed for that throttle position(abut 2500) then drop to 1400 for lockup. the car actually looses acceleration during this period.
when there is a stockish converter the 3-4 shift is harsh.
2.have a generic output or cooling fan control
the last part is a bit more in depth about shifting timing.
i did a big upgrade for my friends 4l80e. a few hard parts,roller conversion, friction upgrades and a d3 transbrake. line pressure is now fixed, no accumulators and the trans should be reliable to 1000hp. the on thing i didn't expect is the increase in time in the 1-2 shift. a 1-2 shift is taking .7-.8 seconds not slipping just a delay, i called the manufacturer and they said that is normal. 2-3 is about the same and 3-4 is quicker than the stock valvebody with shiftkit. i looked into this after the first few runs at the track looked goofy
too short time.png (36.57 KiB) Viewed 133 times
then i overlayed the 1-2 shift from before and after the upgrade. the darker colors is before and the greyed is after
i increased the shift time some and had him take a run he said it was acting funny during the shift, the timing retard came back right before the shift and boost target get upped right at the actual shift occurs, it was working against what we are trying to do, so i just disabled it till hopefully the code can get a few changes.
this is my proposal on this. splitting the shift time into 2 sections. ill just call it A and B for the time being.
in region A the beginning is when the shift is commanded and the end of it is where the shift actually starts. for all intents and purposes A is still in the previous gear transfering torque without slipping or ratio change. this seems to me to be the time in which it takes for the field in the solenoid to colapse plus the time it takes to vent the signal line and move the valves nessesary to make a shift.
region B is where the shift actually occurs.
for region A there is no point in doing torque reduction(timing retard), i would like this to happen in region B.
there is a possibility that once a 1-2 shift has been commanded it can return to 1st if it is reapplied while still in region A, if that is useful or not.
with this trans and what i'd like to see done there would need to be different shift times for different gears
i would also like the "GEAR" to be either split up into "commanded gear" and "in gear" where "in gear" is what is sent to the engine controller so boost by gear dosent come before it is actually in gear or have "GEAR" that is broadcasted after shift time is completed insted of when it is comannded.
ashford
Re: a few feature requests
Postby ashford » Thu Jun 22, 2017 5:09 am
i forgot a simple one
can there be a 2 or 3 point idle step/pwm adder it would be idle adder vs vehicle speed. at some point around 4-8 mph engine torque draw becomes zero at idle and is no longer needed. if i use it so that n vs d results on the ms closed loop idle is doing nothing i get a nice cruise control around 25mph
ashford
Postby LT401Vette » Mon Jun 26, 2017 8:35 am
I see the very same thing in my car.
I have to target shifting by 6500 RPM to shift by 7200.
That is a work around, but it has other fallout issues.
1) Ignition retard is rendered useless, as it retards when the shift is triggered so you are back to full timing by the time the shift actually starts to happen.
2) changes to rate of acceleration such as a nitrous pass or adding/removing boost make your delta RPM change and shift RPM change.
If there was a configurable shift time delay for each gear, it would help, but to help with #2, it really needs to predict the delay based on delta RPM.
Postby whittlebeast » Mon Jun 26, 2017 9:52 am
I think it comes down to expected shift time (from the time the ECU commands a shift until the time that the clutches in the transition and what is that a function of?
Torque from the motor (generally a function the PW)
HP from the motor (generally a function of the duty cycle)
RPM per sec accel rate of the motor (generally a function of mass of the car, gear ratio of the gear that you are coming from and the two things above)
And if the throttle position is changing (this one may be the really tough part to model)
And if there is a better way to model this in some sort of table.
Andy
whittlebeast
Postby Raymond_B » Mon Jun 26, 2017 10:55 am
Have you noticed *more* of a delay with the MS over other trans controllers? Or you are simply trying to eliminate any delay? The reason I ask is when I used to do chip tuning you never actually used the specific RPM you wanted the shift to happen because of the mechanical delay in the trans (like what whittlebeast posted). So I would always command it a few hundred RPM lower, sometimes even more if it was a stock trans.
1995 Ford Lightning. Dart based 427 Windsor, Novi 2000, full sequential, E-85, etc. MS3/3X
Friends don't let friends share tunes...
Raymond_B
Postby ashford » Mon Jun 26, 2017 4:41 pm
Raymond_B wrote:Have you noticed *more* of a delay with the MS over other trans controllers? Or you are simply trying to eliminate any delay? The reason I ask is when I used to do chip tuning you never actually used the specific RPM you wanted the shift to happen because of the mechanical delay in the trans (like what whittlebeast posted). So I would always command it a few hundred RPM lower, sometimes even more if it was a stock trans.
im not really worried about the delay itself, i can tune around it. my gripe is that torque reduction comes at the wrong time or for a long time, it only needs to be in the last 1/3rd or so of the comannded to completed time. the other one is that if doing boost by gear. boost comes up at the comanded time so it is there in the last part of the gear and during the shift.
i have tuned oem pcms, gm adapts line pressure to meet programed shift times to an extent and learns shift time like a ltft and adjust torqe reduction to match the transition of gears. ford has a goofy torque based system.
ashford
Postby Raymond_B » Mon Jun 26, 2017 7:25 pm
Gotcha, and yes Ford's torque stuff is weird!
Raymond_B
Return to Transmission Control
