Chrysler 46RE trans control
Postby auburncasey » Tue Nov 28, 2017 11:45 am
I read through an earlier string on the Chrysler 41TE. I have a similar situation in that I have an early Chrysler Hemi coupled up to a Chrysler 46RE 4 speed O/D trans (A518E). The engine is controlled with a MS3X-V3.57 setup and the preferred method for trans control would be an MS product talking through the CAN bus. There are a few other options out there for trans control, but they are prohibitively expensive and I have no idea if they will communicate well with the MS3X.
I grew up around carbs and distributors. I'm not a coder and know just enough about tuning to be dangerous. There are thousands of this transmission series "out there". I'm hoping the gurus or the members of this forum (that may be redundant) can offer some advice on which product to use (Microsquirt, MSGIO, ??) and what code to use for starters. I'll spend the time and money to acquire the hardware and with some help from the forum try to get the trans under control. Matt Cramer said MS could own the market for standalone Chrysler trans controllers with a Microsquirt solution several years ago. I think the statement is still true today.
Looking for advice on where/how to start this journey................
auburncasey
Re: Chrysler 46RE trans control
Postby steveh66 » Thu Dec 07, 2017 10:26 am
so all those 4*R* series are all the same from 42RE to 48RE.
4 stand for 4 speed
2 stand for torque capability of 2 to 8
R is for rear wheel drive
E is for electrically controlled ( H for Hydraulics)
Its basically a Hydraulic controlled 3 speed with a 4th gear and lock up. The electrically controll is mainly the governor pressure at 1 psi per MPH.
Read up on my other posts. I have this bench build and it should work. I did not like the staged approached for the governor pressure control and could not get support for this. Parked the project for a while now.
May just use a Hydraulic controlled one and the board for lock up and 4th gear.
Steve
steveh66
Postby 440roadrunner » Thu Dec 07, 2017 9:04 pm
I'm not smart enough, wish someone would LOL
In the meantime you could put a manual valve body/ kit in the thing.
440roadrunner
Postby steveh66 » Fri Dec 08, 2017 7:49 am
You probably don even need a manual kit in it, if you disconnect the governor it should go to the highest hydraulically operated gear which is 3. 1 and 2 could be manually selected. 4 (O/D) and TTC would be electrical.
Those transmissions are just a 727 with some bolt ones for 4th and lock up.
Steve
steveh66
Postby 440roadrunner » Fri Dec 08, 2017 10:36 pm
steveh66 wrote:You probably don even need a manual kit in it, if you disconnect the governor it should go to the highest hydraulically operated gear which is 3. 1 and 2 could be manually selected. 4 (O/D) and TTC would be electrical.
Steve
Are you sure that works?
I bought a 96? 97? Dodge 1500 I junked out, drove it home. It only had 3rd gear. Shifter position did not matter. When I pulled it apart "I thought" the transmission electrical connector was loose but it snapped apart and I was not sure.
440roadrunner
Postby steveh66 » Mon Dec 11, 2017 1:17 pm
I thought it should... But have never tried it. Will have to review the hydro schematics again.
You might be right as a disconnected gov will cause high gov pressure and that might prevent the down shift to the low gears (though the selector) preventing over rev.
Good point.
Steve
steveh66
Return to Transmission Control
