Solenoid A and B stats not logged ?
Postby kikkegek » Fri Jan 12, 2018 8:05 am
hi guys,
i made a log file now that my trans shifts like I wannt. I cant seem to find the signal/channel for FIDLE and FUELPUMP that are used for SOLENOID A and B of my 4L80E.
are they logged under a different name?
i have attached the log file for you guys to check it out.
https://drive.google.com/open?id=1zh9i3wzV3MWcEg0Fm_U4sl09w327EDb_
kikkegek
Re: Solenoid A and B stats not logged ?
Postby LAV1000 » Sat Jan 13, 2018 1:39 pm
LAV1000
Postby kikkegek » Sat Jan 13, 2018 1:48 pm
LAV1000 wrote:Check this one :D
viewtopic.php?f=138&t=68039
;-) thats my topic. and what I noticed in shadow Dash is that the solenoid stats are not what I expect every now and then. So Id like to check a datalog on it.
but they dont seem to be in the data log. from what I can judge
kikkegek
Postby LAV1000 » Sun Jan 14, 2018 1:47 am
Made a printscreen of your Datalog 2018-01-12-14.11.
And there is a SolStat.
Solstat !.png (46.62 KiB) Viewed 51 times
LAV1000
Postby kikkegek » Sun Jan 14, 2018 3:10 pm
ok, thank you.
I was looking for the FIDLE and FUELPUMP output signals, because thats what the Solenoid A and B are connected to physically.
Solstat in the manual says:
SolStat
A bitfield representing the solenoid outputs.
but is does not say "what or how it represents" those solenoids?
Guess I dont know how to read this Solstat and know which solenoids are acitvated
kikkegek
Postby LAV1000 » Mon Jan 15, 2018 9:53 am
Eh, second posting jn the forementioned topic ??
LAV1000
Postby kikkegek » Mon Jan 15, 2018 11:07 am
thanks, but thats not quite correct then. I checked my logs and thiss is what I found.
Solstats from Shadow Dash:
Code: Select all
Sol1 = Shift solenoid A
Sol2 = Shift solenoid B
Sol3 = Line pressure solenoid
Sol4 = Lockup on/off
and this is whats avaiilable in the log file:
megalogviewer solstats
during driving I see SOL A and B sometimes turn off and on, while there are no gear changes....thats why I wanted to check the logs to see if that a glitch in the MS Shadow Dash app i need t report of if the trans is actually switching solenoid A and B on/off for some reason.
so far I can judge right noww, there is no way in the available data that is logged, to see wich solenoid is activated. I wonder wwhy? because they are stock outputs you'd expect to see in the log files. so maybe something simple that can be fixed for future fiirmware?
kikkegek
Return to Transmission Control
