TransStim kits are now in stock and ready to order!
We've put together a batch of TransStim kits to use to test out transmission control devices. These simulate seven general purpose outputs, a VSS signal, a transmission temperature sensor, a switch type gear selector, paddle shift buttons, and a brake switch. The kits are priced at $65. Since neither a GPIO board nor a MicroSquirt board has a mating connector to their AMPSEALs, this uses screw type terminals and allows you to make an adapter harness.
TransStims - now available in kit form
Re: TransStims - now available in kit form
Wow. Thanks Matt! I might just have to add this to my shopping cart. It's great to see new products for the DIY user that makes the whole programming world easier to work with. Thanks to you and all involved in the whole MS community that makes things like this happen
