Evening Guys, Need some help..
While trying to connect microsquirt V3 for 4L80 for the first time I get a Firmware Signature Mismatch (see screen shot below). My project serial sig is Trans 00028.6 and the megasquirt serial sig is 00026.7. Can someone explain what this message means and why the #'s are different. I have TS version 2.6.19 and trans release 1.01. I tried to update ECM definition with the correct Trans ini. file but still no luck. What will happen if I connect anyway..Appreciate any input. Thanks
Re: Firmware Signature Mismatch
The correct matching trans.ini file is provided in the trans 1.0.1 firmware zip. You need to click "Update ECU definition" and then browse to the correct place.
Thanks James. Not sure what my issue was yesterday, but I tried the same trans file yesterday with no luck. Today it worked the first try. I appreciate the help.
