Messing around tonight I found a debounce value in the trans_main file.
Code: Select all
} else if ((paddle_phase == 1) || (paddle_phase == 2)) {
if ((pad_mode != 1) && (pad_mode != 2)) { // was pressed, now released
paddle_timer = 78; // 10ms debounce
paddle_phase += 2;
If I change this paddle debounce to a higher value, does it require reflashing the firmware for change to take effect if trans_main is modified? Will this actually change the paddle debounce value for the "MS2" selection?
