I will try to help if I can. I may have missed it, what transmission are you running? I noticed the 2J engine, is it an A341 or A340?
EDIT* just saw 4l80e in the post.
Transmission not shifting. *solved
Re: Transmission not shifting
Updated 6/20/18:
87 Supra-3.0 1.5JZ-A340 trans
MS2 ECU
MS2 Trans controller
MS2 ECU
This is for my LS powered 240z
So this is where I'm at. Since the tranny wants to see open or high voltage or grounded, tomorrow I'm going to drive the car till it faults again. Then depending on 4th gear postion status ill start with pin A and cut it and leave it open or ground it. Do that for all pins till either it's fixed in TS or the problem still exists. This will lead me to the tranny or controller as being the sole problem
Working with my tranny guy who supplied the electronic D3 trans brake, as per instructions, Pin A wire gets cut and moved to a new pressure switch tapped into the valve body. He is sending a new switch out for me to install. So I'm really anxious to see if by cutting and doing some external with pin A solves my issues and then I know it's the add on pressure sensor
Problem pretty much solved. I was able to cut the A wire while driving that Gos to the external valve body pressure switch and it went back to gear 4 and drive perfect on the way home So dropping the pan tonight and and replacing that switch and will report back tomorrow
Re: Transmission not shifting. *solved
New pressure switch installed and all is good
