I simply tee'd into the single cruise wire from a 5 volt limiting circuit in the TPS line.slow_hemi6 wrote:You must be using something to get your variable voltage back to the MS already. You would use the same wire.Turbofreakdotcom wrote: wouldn't I still need another wire going through to the MS?
Looking from a different perspective now.
