4L60E TO MAZDA TRANSMISSION
'Microsquirt' Transmission Control development and support.
white probe
Post by white probe »
Hi all, I am looking to use the 4L60E solenoid configuration to control a mazda GF4A-EL transmission, the question is can I use the trans range sensor or neutral switch instead of the pressure switch manifold signal, tell the computer when the car is in drive or 2nd using the neutral switch because in this transmission I dont have pressure switch manifold, thanks.
prof315
Re: 4L60E TO MAZDA TRANSMISSION
Post by prof315 »
Why not simply post up the info on the shift solenoid patterns, range switch, TCC, VSS and anything else pertinent and ask James to add it?
Support the developers!
white probe
Good morning, I use the range sensor signal with 3 diodes in and 12v made box to simulate pressure manifold signal and works great, also I use 3 relays and 3 diodes with the 2 output solenoid signals to control the 3 shift solenoids, now I am looking instead of 3 relays building a configuration with transistors, one question how I can select a imput to see line pressure, thanks.
