[Feature Request] How to get ADC to MS2?
'Microsquirt' Transmission Control development and support.
acab
Post by acab »
Hello!
I have MS2 and Microsquirt for transmission control.
I have no free pins for sensors on my MS2, but i have much free ADC inputs in Microsquirt.
How to get data from micro to ms2extra?
for example fuel pressure, oil temp and other stuff.
dontz125
Re: How to get ADC to MS2?
Post by dontz125 »
Take a look at the IO Box manual; it MIGHT work.
prof315
Post by prof315 »
I _think_ only MS3 supports using the spare I/O as additional CAN I/O
Support the developers!
dontz125
Post by dontz125 »
Having just spent the better part of an hour rummaging through various .ini config files as well as forum discussions both here and on jbperf, I'm going to guess at a guess. Nothing should break on either device, but be aware that results really should be tested to prevent stupid in = stupid out. Here we go:
The ADCs on the uS-TC are part of the output channels, and should be able to be read in CAN. The device is 7, I *THINK* the table is 7, the offset for ADC0 is 16, and the offset for ADC4 is 24; note that ADC4 is the voltage input, not an external sensor. This info will arrive at the MS2 as gpioadc0-gpioadc7, and I'm fairly certain the data is going to be in raw format, 0-1023 ADC counts. You'll need to come up with a custom.ini to allow TS to show it as a meaningful gauge value.
Good luck!
