I have verified that manual mode does work as expected, but when I put the switched ground input to it, I get nothing. I've tried it on both SPAREADC2 and O2 inputs. Giving them ground and will not engage commanded gear like it will when I select "Manual" mode in the settings. Everything else works great, but can't seem to make this work correctly when trying to use the dash switch to engage manual mode. I've verified the wiring to ensure ground is going to each of those pins I tried. Thinking about reloading firmware, but figured I'd ask first. Has 1.0.1 in it on V3 micro controlling 4l80e.
Thanks,
Andrew
Cant get Manual-selectable mode to function
Re: Cant get Manual-selectable mode to function
I had some issues too. Try either tps or clt inputs and try again. One worked for me the other didn't. I just don't remember right off hand
I was just screwing around with it and got it to work on FLEX input. O2 and SPAREADC2 definitely do not work though.
